Media Encoder Multiple files Work area
MAris Milgravis
on Jun 15, 2016 at 3:30:51 pm
How can I set Media encoder "Source Range" default to "Work area" ?
The problem is I 'm working with large quantities of files exported from Premiere in Media Encoder.
When you select multiple files and edit export settings it's applied to all files you selected.
All settings can be changed for multiple files except for "Source Range" - I don't know why Adobe done that - must be some weird reason...
So default setting is "Sequence in/out" I changed my workflow and set up In/Out points in Sequences where i used work area but it still don't work - Encoder is taking entire sequence for rendering.
So i was wondering is there way to set "Source Range" default to "Work area" ?
