what are the fastest/best export settings for jpeg + audio (for youtube music)
Jim Svensson
on Jun 14, 2016 at 2:39:40 pm
Hi
I am creating meditation music for youtube and my tracks are usually 3 hours long. I use Jpeg picture background for youtube.
I am looking for the best settings for 720HD.
Now I am using this:
Format: H.264
Frame Rate: 10
Aspect: Square Pixels 1.0
Profile: Main ---- Level:4.2
Encoding: VBR 1pass, Target Bitr:5 Max Bitr:5
Key frame distance: 300
I also checked "use previews"
No editing in premiere, just need to "glue" mp3 320kbps + jpeg...
Are there better options? I am completely new to exporting, I want to shorten my exporting time.
Oki Pienandoro
Re: what are the fastest/best export settings for jpeg + audio (for youtube music)
on Jun 14, 2016 at 7:23:26 pm
If it's only "glue" jpg and mp3, the fastest approach will be avisynth and export with x.264 fast preset, still image tune . Also since the image is static, there's no need to set a high bitrate (5MBps) for video, what matter is your audio bitrate.
Or you can do this with ffmpeg on one go:
ffmpeg -loop 1 -i image.jpg -i audio.wav -c:v libx264 -tune stillimage -c:a aac -strict experimental -b:a 192k -pix_fmt yuv420p -shortest out.mp4
Taken from here :
http://superuser.com/questions/1041816/combine-one-image-one-audio-file-to-...
Sorry for the english, not native speaker.
Jim Svensson
on Jun 14, 2016 at 9:48:43 pm
tried that ffmpeg code, but it takes way longer than with premiere and my settings...
Oki Pienandoro
on Jun 15, 2016 at 1:45:15 am
use fast preset or use fastest preset in x.264, see if it helps., or use avisynth like i told you, encode with megui with the same x.264 preset.
Jim Svensson
on Jun 15, 2016 at 6:57:29 am
I tried this one:
ffmpeg -r 1 -loop 1 -i 1.jpg -i 1.mp3 -acodec copy -r 1 -shortest -vf scale=1280:720 ep1.flv
worked fantastically! rendered 3 hours long video in 1min!
