SSD vs RAID?
Max Baker
SSD vs RAID?
on Feb 27, 2016 at 5:58:38 pm
So, Adobe recommends RAID configuration for working uncompressed video in Premiere Pro, but will a single SSD 3.0 handle the workload given its faster performance over a standard HDD?
Max
Tero Ahlfors
Re: SSD vs RAID?
on Feb 27, 2016 at 6:39:34 pm
SSD's are fast but there are still pros to using RAIDs.
-Redundancy. When your SSD fails, that's it. It's done and your data is gone. If you have a RAID5 one drive can fail and it's still usable and you can rebuild. On a RAID6 two drives can fail and you still can rebuild that.
-Price/space. Larger SSDs are pretty expensive and small. When dealing with uncompressed stuff (especially at higher resolutions/framerates) a terabyte won't cut it. You can get pretty big volumes on a RAID setup pretty cheaply.
