Stuttering footage 50fps modified to 25fps in premiere. Shot at shutter speed 100th sec
Christopher Tegg
on Jan 3, 2016 at 6:26:46 am
Help.I've just shot a video at 50fps shutter 10Oth sec. But it is stuttering on pans.
I modified to 25fps in premiere. How can I fix this?
Cheers.
Ivan Myles
Re: Stuttering footage 50fps modified to 25fps in premiere. Shot at shutter speed 100th sec
on Jan 3, 2016 at 4:00:12 pm
Enable frame blending.
Jeff Pulera
on Jan 4, 2016 at 7:27:54 pm
Have you tried NOT modifying the frame rate, sinply dropping the 50p clip into 25p sequence? Premiere should play just fine. Frame blending is sometimes handy, but often times has it's own side-effects.
Jeff Pulera
Safe Harbor Computers
