Apply Luma Curve Over Time?
Kirk Darling
on Nov 5, 2015 at 5:18:51 am
Is there a way to start a clip with a Luma Curve adjustment and then taper off to no adjustment after a few seconds?
Ivan Myles
Re: Apply Luma Curve Over Time?
on Nov 23, 2015 at 11:34:11 am
- Make copies of the clip.
- To each copy apply a luma curve at different levels from lightest to darkest or vice versa.
- Stack the clips above each other on different tracks.
- Adjust opacity to fade from one clip to another over the transition period.
