2 clips into one. Watermark and video footage.
Ruud de Ruijter
on Oct 22, 2015 at 10:56:11 am
I have 2 clips: a watermark and a footage.
The watermark is ontop of the footage.
I also have an intro with a dissolve transition.
My problem is when I preview it you can see that the watermark is suddenly there and is not getting dissolved.
Is there a way to do this?
This is what my timeline looks like:
Steve Brame
Re: 2 clips into one. Watermark and video footage.
on Oct 22, 2015 at 1:17:17 pm
Select both the watermark clip and the footage below it. Right-click and select Nest. That combined the two clips into one nested clip, and the dissolve should work on both.
Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia GeForce GTX 770 * Windows 7 Premium 64bit * System Drive - WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) - WD Velociraptor 10K drive 600GB * Media Drive - 2TB RAID0 (4 - WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC * QuickTime 7.7.5
"98% of all computer issues can be solved by simply pressing 'F1'."
Steve Brame
creative illusions Productions
Tero Ahlfors
on Oct 23, 2015 at 4:05:24 am
Or add the same dissolve on the watermark with the same length.
Ruud de Ruijter
on Oct 23, 2015 at 1:50:23 pm
Thank you, this is exactly what I wanted.
I have two more questions though.
as you can see in my image the music transition is only on 1 side.
Is there a way to make it like half on each clip?
And can the transition that is on the left clip be placed on the right clip?
When I try to drag it to the right side, it doesn't do anything?
Steve Brame
on Oct 23, 2015 at 2:33:32 pm
See my answer.
Steve Brame
Tero Ahlfors
on Oct 23, 2015 at 2:54:24 pm
You need heads and/or tails for dissolves.
Ruud de Ruijter
on Oct 23, 2015 at 3:01:53 pm
[Steve Brame] "See my answer."
Okay, but now I get an errors saying it doesn't have enough footage.
[Tero Ahlfors] "You need heads and/or tails for dissolves."
What do you mean by that?
Steve Brame
on Oct 23, 2015 at 8:00:56 pm
'Heads and Tails' are the areas of video beyond where a clip is cut. For example, if you have a 5 second clip, and you shorten the tail, or end of the clip 1 second, making the clip length 4 secs, you have a 1 second 'tail'.
https://helpx.adobe.com/premiere-pro/using/transition-overview-applying-tra...
Steve Brame
Ruud de Ruijter
on Oct 24, 2015 at 5:28:37 am
How can I keep those or get those heads?
Tero Ahlfors
on Oct 24, 2015 at 6:58:08 am
Don't use the complete clip for the edit. Leave a few frames from the end or the beginning of the clip to the dissolve.
Ruud de Ruijter
on Oct 29, 2015 at 4:43:39 pm
[Tero Ahlfors] "Don't use the complete clip for the edit. Leave a few frames from the end or the beginning of the clip to the dissolve."
What did you mean by that, because what I did was this:
I got a video from 15 minutes and then cut a bit from the start and the end with the cut tool (shortcut c).
Ruud de Ruijter
on Oct 29, 2015 at 10:56:32 pm
I fixed it, thank you.
I had to cut a small piece of the intro.
