Audio increment Adjustments in Premiere CC
Jordan t. Nagasako
on Jun 8, 2016 at 7:30:26 am
Hi I have two issues I'm trying to figure out with Premiere but can't seem to find the answer.
1) can you adjust the audio so that when raising the levels from the timeline it will go higher than 6.02db like up to 12 db like FCP 7 does? Or do I have to you use the gain setting after I'm up to 6.02db it's just one extra step I'd prefer to avoid.
2) when adjusting audio levels is there away where it is larger increments than such small fractions of db se still how it's 1.52 Id rather it be just 1.50 or 2.0? I would be nice if the increments weren't so small so that it was easy to adjust the levels between clips.
Thanks so much!
Pierpaolo Ferlaino
Re: Audio increment Adjustments in Premiere CC
on Jun 8, 2016 at 8:24:25 am
No... but you can adjust audio gain, right click and select "audio gain"... beware not to clip the waveform...
I don't know of a way on the timeline but you can use the audio clip mixer and type a value...
Jordan Nagasako
on Jun 8, 2016 at 6:36:06 pm
okay sounds good thanks!
