ultrakey playback issues
John McRae
on May 30, 2016 at 8:41:24 am
Hi Guys,
I’m having issues with ultra-key in play back. In areas of high movement - (eg: hands) the keyed image breaks up horizontally.(image attached) Using Adobe CC 2015.
Chris Wright
Re: ultrakey playback issues
on May 30, 2016 at 3:22:11 pm
1. right click-interpret modify clip field order conform to upperfield
2. in sequence setting, video fields upper field.
3. in media encoder upper fields(keeping interlacing for future) or progressive(youtube)
John McRae
on May 30, 2016 at 11:20:13 pm
Thanks Chris,
Found other issues as well. Background was a .bmp which was a problem. Replaced with .jpeg. Also using the opacity tool to remove rubbish from green screen created an issue.
