Loud audio feedback on playback of cross fade (sequence imported from FCP 7)
Crescent Diamond
on May 26, 2016 at 5:32:22 pm
Hey all. So I exported a 90 min sequence from FCP 7 (had to do it in chunks) but eventually got the whole thing in Premiere Pro CC 2015 (9.2.0).
Problem is: loud feedback when playing back audio Constant Power cross fades, but not every time, if I go back to spot after playing it and play again, the feedback SOMETIMES does not play. When I delete the crossfade, the feedback does not play but when I add a new crossfade (Constant or Exponential) in Premiere, it plays again.
What I've tried:
-created a new sequence in Premiere and copied and pasted
-deleted render files
-rendered audio
-deleted media cache
There are no audio plugin effects or any effects except volume on these clips besides the fade.
Also to note: I edit projects that originate in Premiere every day all day and have not encountered this particular problem with any other project. No help from Adobe Support.
System info:
Thanks, Crescent D.
