H.263 encoding
Stamos Dimitro
H.263 encoding
on May 25, 2016 at 2:19:01 pm
So I have been asked by my client to deliver the finished video in these awkward specs:
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 156 MiB
Duration : 2mn 56s
Overall bit rate : 7 413 Kbps
Encoded date : UTC 2014-09-30 19:46:29
Tagged date : UTC 2014-09-30 19:46:29
Writing application : Lavf51.12.1
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 2mn 56s
Bit rate : 7 411 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.143
Stream size : 156 MiB (100%)
Writing library : Lavc51.40.4
Language : English
After some research I realized that Premiere has the option for MPEG-4 export (different than H.264 export), but the settings are very limited. Specifically it won't let you make the resolution more than 720x576. So how can I export the requested file?
