CC2015.2 Can't Add Transition Effect
Jeff Coleman
on May 21, 2016 at 4:33:09 am
Unable to drag an effect out of the Video Transitions folder on to an edit.
I can apply the default transition to the edit via keyboard shortcut, but can't drag an effect to the edit. (Can't drag "Slide" to the edit, but if I make "Slide" the default transition, I can apply the default transition and have a slide transition effect on the edit--- not very convenient way to work.)
Using the same clip in CC2014 doesn't have this problem as I can drag effects to the edit without a problem. In CC2015 I just get the solid hand with the small circle with a slash in it when trying to drag an effect to the timeline.
Is this a bug or operator error of some sort?
CC2015.2 (9.20 (41) Build)
OS 10.11.5
Late 2013 Mac Pro
