Render out different sections of the same comp?
Ben Lewis
on May 19, 2016 at 4:47:40 pm
HI I am trying to render out multiple sections of the same comp from AE. So basically I want say from 00:00 to 00:10 then 00:40 to 00:50 etc
I'm sure I've heard of a plug in to do this.
Duke Sweden
Re: Render out different sections of the same comp?
on May 19, 2016 at 8:28:54 pm
If you want to do one at a time you can just adjust the markers on the timeline (the two little blue knoblets) to the sections you want to render, just don't "Trim to comp". When done with 00:00 to 00:10 then move the markers to 00:10 to 00:20, etc.
Ben Lewis
on May 19, 2016 at 8:31:45 pm
Thanks mate but I'm wanting to render out all at the same time. I'm sure I have seen a plug in for this.
Duke Sweden
on May 19, 2016 at 10:20:01 pm
Oh, ok. BG Renderer, by any chance?
http://aescripts.com/bg-renderer/
Ben Lewis
on May 20, 2016 at 7:43:11 am
No but thats cool. Just to clarify I want to export different sections of one comp. So imagine if you could set multiple work area sections then render all of those out at once.
Cheers
Ben
Stephen Abbott
on May 20, 2016 at 8:51:27 am
Hey Ben,
Provided you don't change the timing of the master sequence, you can do this with nested sequences.
1) Take your master seq and nest it in a new seq.
2) Trim the nested master seq to the desired length (markers might make this easier).
3) Create a new sequence and repeat 1 and 2 for each area you want to render out separately.
4) Select each sequence in the project window and hit File > Export > Media. Since you've selected more than one sequence, you will be forced to send the renders to the Adobe Media Encoder queue.
5) VoilĂ !
The caveat: things will get a bit messy if you doing any ripple-editing on the master sequence...
S
Stephen Abbott
Alex Udell
on May 20, 2016 at 5:06:34 pm
Are we talking about AE or PPro here?
in PPro....
just set IN and OUT and Queue to Adobe Media Encoder
then repeat with a different IN and OUT as many times as you need...
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Ben Lewis
on May 20, 2016 at 6:01:25 pm
Hi Alex, thanks for posting. I was talking about AE. A similar workflow as the one you suggest in AE is what I am trying to achieve.
Cheers
Ben
Alex Udell
on May 21, 2016 at 1:33:09 pm
If you use AE and media encode the same thing applies.
Set your work area to the frame rage you want....
then with the comp selected
Composition > Add to Media Encoder Queue
go back to comp
Adjust work area frame range
both will be added to the media encoder with different frame rages for rendering...
hth,
Alex Udell
Ben Lewis
on May 21, 2016 at 8:34:42 pm
Thank you.
Dave LaRonde
Re: nder out different sections of the same comp?
on May 22, 2016 at 2:52:05 am
If you're rendering out of AE, you've got no choice but to duplicate the comp for easc clip, set the work areas to the portions you want, and add them all to the AE Render Queue. You can then render them all in a batch.
Dave LaRonde
Promotion Producer
Alex Udell
on May 23, 2016 at 8:10:03 pm
Dave....
with AME you can do this without the duplication.....
Alex Udell
Dave LaRonde
on May 23, 2016 at 8:33:26 pm
Yeah, but I think it's a bigger hassle with AME. Okay, maybe I'm nuts, but that's me.
Dave LaRonde
Promotion Producer
Ben Lewis
on May 23, 2016 at 9:44:23 pm
I think I'm nuts too Dave. But yes AME is an option. Can anyone remember the name of the plug in which lets you select multiple in and outs from the time line and export?
