Are bracket key audio adjustments adjustable?
Ron Craig
on May 13, 2016 at 10:40:31 pm
What I mean by that subject line is: I use the bracket keys (without the shift key) to adjust a clip's audio level. But the amount that those keystrokes increase or decrease the clip's audio is more than I would like. I'd like to be able to make smaller adjustments with each keystroke. Is there a way to adjust that? Thanks.
Ron Craig
Re: Are bracket key audio adjustments adjustable?
on May 13, 2016 at 10:43:25 pm
Well, I found the answer quickly. There are choices for "Nudge audio volume +1 or -1 db" in the keyboard shortcuts. Hadn't found that before. I'm going to assign those commands to the bracket keys.
