No Audio Meter Scale
Jeff Coleman
on May 10, 2016 at 2:27:02 pm
I don't have dB scale in my Audio Meter pane (i.e., no graticule/numbers on right side of window). BTW, the scale IS present in PPro 2014.2/8.2.0 (65)
Is there a way to turn that on/off, or is it a bug?
Premiere Pro 2015.2 [9.2.0 (41)]
Mac Pro Late 2013, 8-core, AMD FirePro D700
OS 10.9.5
audio meter
VU
scale
graticule
Premiere Pro CC 2015
Mac OS
Ann Bens
Re: No Audio Meter Scale
on May 10, 2016 at 11:00:24 pm
Make the audio meter wider.
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Jeff Coleman
on May 11, 2016 at 12:51:01 pm
Thanks, but it seems to me that I shouldn't have to make the audio meter any bigger in PPro 2015 than I had it in PPro 2014 in order to see the scale.
However, if I make the audio meter REALLY wide, it turns the meter on its side (so that the level indicator is rising from left-to-right) and displays a scale at the bottom of the pane. This is not desirable.
Another suggestion?
Jeff Coleman
Re: No Audio Meter Scale SOLVED
on May 11, 2016 at 2:40:08 pm
Figured it out. So simple....
The entire layout was a bit too big on the monitor. I slid over the whole lefthand PPro display layout and I could see the scale on the right hand side of the meter now. I shrunk the window a tad and filled the screen.
All is well now.
Thanks.
