what effect?
Mark Pirres
what effect?
on May 9, 2016 at 11:33:02 am
Hello,
I'm trying to figure out the effects used in the following videos:
at:
- 3:12 is it actually a flare or some an effect added?
https://vimeo.com/77127939 at:
- 00:25: there's a cross fade but the clips seems to brighten up too?
- 00:35: is it a flare coming through from below? or an effect?
thanks in advance for any reply
thanks
Aleksey Tarasov
Re: what effect?
on May 9, 2016 at 11:57:30 am
light leaks
Mark Pirres
Re: what effect?
on May 9, 2016 at 12:55:08 pm
Thanks for getting back.
Well, I have some light leaks installed but in the above instances - especially the first one - it seems to me to be a bit different: light leaks normally come in a bit randomly from all sort of directions. Here they seem more directionally applied. Also, they are normally used to transition to another shot while in the first case the shot stays the same? I know they don't look too complicated but if there's any tutorial someone could direct me to, I'd really appreciate it.
Duke Sweden
Re: what effect?
on May 9, 2016 at 5:26:01 pm
Damaged film? Like the plugin Genarts makes?
Wallace Adrian D'Alessio
Re: what effect?
on May 10, 2016 at 10:55:30 am
No speciality needed.
Make a luminance mask of your liking in photoshop and overlay.
Experiment a bit with timeing and opacity.
Use blend mode to tune to your preference.
Knowing how grey scale masks can interact with layers is an essential basic skill.
Adrian D'Alessio aka; Fluxstringer
fluxstringer@gmail.com
http://www.facebook.com/FluxStringer
http://www.linkedin.com/in/fluxstreamcommunications
http://twitter.com/FluxStringer
http://mog.com/FluxMuse
Mark Pirres
Re: what effect?
on May 10, 2016 at 6:00:10 pm
Ok thanks everyone for the kind replies!
