forward select tool selects ALL clips in all tracks
Duke Sweden
on May 6, 2016 at 2:27:31 pm
I've seen more than one article explaining all of the tools in Premiere Pro and they all say that to select all of the clips in a track you should use the forward select tool and click in the track of clips you want to select, but when I use it, it selects all of the clips in all of the tracks, including the audio tracks. Is this a bug in cc 2015 that hopefully will be fixed in cc 2016 or is that the way it's supposed to work? The same thing happens when I use backward select tool.
