Premiere crashing when adding new clip to timeline
Pete Lewis
on May 5, 2016 at 2:03:09 pm
It seems to come and go. One day everything works fine. The next, I cannot add a video clip (and sometimes even an audio clip) to the timeline without Premiere locking up. I have to go into Task Manager to close it and try again. Sometimes I can add the new clip to a new timeline and then drag that timeline into the original timeline, but even that doesn't always work. I would appreciate nay help if someone has an idea of what I'm doing. I am using Premiere CC 2015.2, Build 9.2.0
Dave LaRonde
Re: Premiere crashing when adding new clip to timeline
on May 5, 2016 at 7:24:06 pm
How much memory is on your machine?
Dave LaRonde
Promotion Producer
Pete Lewis
on May 5, 2016 at 7:30:55 pm
16GB
Dave LaRonde
on May 5, 2016 at 10:28:06 pm
Depending on the footage, you can be a little light on RAM. Since it's cheap, you could install more.
Dave LaRonde
Promotion Producer
Kannan Raghavan
on May 6, 2016 at 5:32:53 am
Hey Pete, please list the specs of the comp you're using. Also, what codec/wrapper you usually use. Would help the gurus here to help you:)
Kannan Raghavan
The Big Toad Films Pte. Ltd.
Wallace Adrian D'Alessio
on May 7, 2016 at 1:07:41 am
Do you have the RAM configged to max allowed in prefs?
I use 16 GB and Adobe sets the min of 3GB for other programs and services.
Unless you are doing 3D layering and or a huge layer load with unrendered effect your should have enough for 1080p HD.
Adrian D'Alessio aka; Fluxstringer
fluxstringer@gmail.com
http://www.facebook.com/FluxStringer
http://www.linkedin.com/in/fluxstreamcommunications
http://twitter.com/FluxStringer
http://mog.com/FluxMuse
