strange sub-clip behavior, open-ended out?
Paul Dougherty
on May 3, 2016 at 1:09:20 pm
I saw many people post the same problem on the Adobe forum but don't see a solution
I'm at home so I can't offer the Premiere version (almost sure it's the latest) but when I edit a sub-clip into my time line the (say) 2 sec clip will run the length of the original master clip… unless I manually set marks on it. Yes "Restrict Trim to subclip boundaries" turned off, but this never used to happen
Thanks in advance,
Paul
p.s. I did search on sub clip limits
Dennis Callan
Re: strange sub-clip behavior, open-ended out?
on Jun 15, 2016 at 7:08:08 pm
Trash prefs to fix this. New subclips will no longer have this problem, but subclips defined before trashing will retain that open-end bug.
