Effect Mask showing on dissolve
Patrick Cella
on Apr 28, 2016 at 4:39:18 pm
I'm using a crop effect with a mask on the lower third to apply a feather to one edge only. When i dissolve the lower in, the mask applies to the video below only during the dissolve. I would like the mask to only apply to the lower third and not on the video on the layer below.
Patrick Cella
Re: Effect Mask showing on dissolve
on Apr 28, 2016 at 8:27:50 pm
I found a workaround, which is not to use the dissolve effect but to use the opacity keyframes to create the dissolve.
Wallace Adrian D'Alessio
on Apr 29, 2016 at 3:35:55 pm
I assume you tried all of the blend modes.
Adrian D'Alessio aka; Fluxstringer
fluxstringer@gmail.com
http://www.facebook.com/FluxStringer
http://www.linkedin.com/in/fluxstreamcommunications
http://twitter.com/FluxStringer
http://mog.com/FluxMuse
