Mystery Jitter/flicker in Premier sequence but not the source file - how to fix?
Rachel Pearl
on Apr 21, 2016 at 5:35:18 pm
HI,
I have a screen capture in a project that is about to go out to a client. When I play the sequence back the screen capture has a bad jitter/flicker. HOwever, when I match back to the clip in the Source window the jittler is not there.
If I export from the sequence, the resulting Quicktime also has the jitter, which is of course, un-acceptable.
How do I fix this?
Rachel
Jon Doughtie
Re: Mystery Jitter/flicker in Premier sequence but not the source file - how to fix?
on Apr 22, 2016 at 3:15:08 pm
What's the wrapper/codec/resolution of the clip giving you trouble? Interlaced or progressive?
What are the timeline settings/resolution you are using?
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Rachel Pearl
on Apr 22, 2016 at 6:34:55 pm
The footageis ProRes 29.97, 1920x1080. The sequence is configured to that as well
It's progressive scan.
Does that help?
