PSD files blurry in playback and export
Carissa Dis
on Apr 17, 2016 at 5:06:41 pm
I have a sequence with PSD files and JPEGS and when the sequenced is paused the image is perfectly sharp and clear...then as soon as I play back the sequence the psd images are blurry and are even blurrier when i exported. I need to export in H264 but I also tried other codecs to see if it would make a difference and it didn't.
I'm thinking the images aren't the right size for the sequence but i'm not sure and also not sure how to fix that issue.
Can anyone help with this?? Thank you!!
Jon Doughtie
Re: PSD files blurry in playback and export
on Apr 18, 2016 at 1:29:55 pm
Hi Carissa. Tell us the pixel resolution of your sequence timeline and the pixel resolution of your images. Have you resized any/all of them for the timeline?
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
