Any ideas on how to find my corrupt frame which is crashing my renders?
Chris Craig
on Apr 16, 2016 at 10:04:07 am
Hi guys
I have captured 10 VHS tapes in the last week, each being 3 hours or longer.
I have exported them all out to encoder and 7 of them are failing because of a corrupt frame. Of the 7, i have found 5 of them early in the timeline, however 2 of them are much later.
I do not have the time to sit and watch these tapes for the corrupt flash frame or two and hoped anyone could suggest a solution.
Im exporting from DV to h264 if this makes any difference.
I have checked the log from encoder and it only tells me how long it has been encoding for and not the frame number it failed at.
Thanks a lot
Chris Craig
Re: Any ideas on how to find my corrupt frame which is crashing my renders?
on Apr 16, 2016 at 10:11:21 am
As soon as i posted, I then thought of a solution.
Rendering as low res image sequence files will help, as it will stop rendering when it reaches the corrupt frame.
