5.1 to mono stems
Erik Lundmark
5.1 to mono stems
on Apr 14, 2016 at 2:59:34 pm
Hi there, is it possible to export a 5.1 surround track where all the 6 tracks are contained within one track, to discreet mono stems?
Thanks.
Trevor Asquerthian
Re: 5.1 to mono stems
on Apr 15, 2016 at 12:32:42 am
If a 5.1 sequence then you can export to a 5.1 wav and check 'export each channel as a seperate file'
If you've a 5.1 source file and you just want to treat it as 6 discrete tracks then modify audio channels to mono.
Erik Lundmark
on Apr 15, 2016 at 5:18:36 am
Thanks for your help. I'll give it a try and post the results.
Erik Lundmark
on Apr 15, 2016 at 11:19:55 pm
Thanks, the check box did it. I had overlooked that on my first attempts.
Much appreciated.
