Mixing down the audio of a Multiclip
Darren Lee
on Apr 14, 2016 at 7:55:32 am
Hi, I'm having problems with the audio when editing a Multiclip, it seems a lot of other people are too https://forums.creativecow.net/thread/3/975940
I have two camera tracks each with their own audio, but I want both cameras to use both audio tracks at the same time. This doesn't seem possible, as when switching cameras it switches the audio too
I thought one way round this would be to blend or mix down both audio channels into one source that I can duplicate on both Audio tracks.
Is this possible without opening an external editor?
Darren Lee
Re: Mixing down the audio of a Multiclip
on Apr 14, 2016 at 8:55:21 am
On hack I tried that seems to work is to make a subsequence of the audio tracks...
Herb Sevush
on Apr 14, 2016 at 12:55:55 pm
[Darren Lee] "I have two camera tracks each with their own audio, but I want both cameras to use both audio tracks at the same time. This doesn't seem possible, as when switching cameras it switches the audio too"
When making your multiclips chose "All cameras" in the audio portion of the dialogue box. In your case this will give you all 4 tracks of audio whenever you lay down a clip.
Herb Sevush
Zebra Productions
nothin' attached to nothin'
"Deciding the spine is the process of editing" F. Bieberkopf
