Scripting in Premiere Pro - Where to start
Ryan McAdam
on Apr 13, 2016 at 6:47:42 pm
I've been writing automation scripts in After Effects for a while now and am familiar with the process and documentation.
I'd like to write some similar scripts for Premiere CC(2015) ,but finding any material on the topic has proven difficult. I did find Premiere's Plug-in and pannel SDKs from the adobe developer site.
http://www.adobe.com/devnet/premiere.html
Didn't really help with the whole getting started process.
Does anyone know of a good guide or tutorial on getting up and running with scripting for Premiere Pro CC(2015)?
Ryan
Herb Sevush
Re: Scripting in Premiere Pro - Where to start
on Apr 14, 2016 at 12:58:00 pm
[Ryan McAdam] "I've been writing automation scripts in After Effects for a while now and am familiar with the process and documentation."
Ppro doesn't have any "scripting" abilities - you can make third party plug-ins, which is something I know nothing about, but there is no scripting automation similar to what you have in AE.
Herb Sevush
Zebra Productions
nothin' attached to nothin'
"Deciding the spine is the process of editing" F. Bieberkopf
Alex Udell
on Apr 14, 2016 at 3:00:31 pm
Hi....
What kinds of things are you thinking about automating?
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Ryan McAdam
on Apr 14, 2016 at 4:17:51 pm
I was hoping to set up a project system for my team. Currently when a team member needs to link to an asset in a project, they need to navigate the folder structure in Dropbox. That sounds simple enough, but our folder structure gets very complicated with different assets and versions, naming conventions and file types. Team members also tend get into the project folders and create sub folders they shouldn't or move/rename things they shouldn't move or rename.
I'm writing a set of tools for after effects that manages all this stuff in the background so team members can access everything they need without wasting time navigating the project files or messing with anything in the project folder.
I'd like to create a similar system for premiere so my video editor can click a button and bring in the most updated file versions without having to go looking for them.
Premiere has a panels sdk (different from the plug-in sdk) that may do the trick but it seems more complex then AE's scripting language and not well documented.
Any thoughts you have on the topic would be great. Thank you.
shawn baden
on Feb 23, 2017 at 11:49:12 pm
Hey Ryan,
Not sure where you are with your Premiere scripting but I'm in the same boat as you. I am very familiar with scripting for AE and am now trying to fumble my way blindly through scripting for Premiere.
I'm using Extendscript, like I do for AE and running the scripts from there - I can't find a way to run the scripts from inside PPro. The only way I know to run them from within PPro is to build a panel - I've been trying to figure that out as well.
There is now a little bit more documentation but still not much. Adobe has done a very poor job of supplying documentation. Here are a few links straight from Adobe:
Very limited api:
https://github.com/Adobe-CEP/Samples/blob/master/PProPanel/payloads/api_doc...
Sample scripts:
https://github.com/Adobe-CEP/Samples/blob/master/PProPanel/jsx/Premiere.jsx...
Ryan McAdam
on Apr 14, 2016 at 4:18:34 pm
Alex Udell
on Apr 14, 2016 at 6:36:44 pm
Hey Ryan....
unfortunately I don't have any insight to the scripting in Ppro...
and I looked a while ago as well....lack of documentation may be intentional at this point....as it might not be as mature as what you'd find in AE.
but if you are looking for a project system take a look at this:
https://frame.io/premiere
may be of some help....and you might not need to code at all...
Alex Udell
Peter Garaway
on Feb 24, 2017 at 12:37:43 am
Hi Ryan,
Are you still looking for some help here?
Shawn - I'll see if I can find out anything.
Peter Garaway
Adobe
Premiere Pro
Ryan McAdam
on Feb 24, 2017 at 3:29:59 am
Yes,
I'm still looking. Anything you have would be great.
Ryan
Peter Garaway
on Feb 24, 2017 at 5:13:01 pm
Hi Ryan -
Email me at pgaraway at adobe dot com
I'll connect you with someone that can lead you in the right direction.
Peter Garaway
Adobe
Premiere Pro
Anna Komarova
on Mar 30, 2017 at 2:53:38 pm
Hi, Ryan!
Have you found out how to set up a project system?
If yes, please, share your solution.
I have practically the same task.
Thank you!
Frank DeCoup
on May 29, 2017 at 5:31:59 pm
Hey guys,
I am having the same problem here.
Did you figure out any solutions yet?
Thank you in advance,
Frank
Arthur Hakhverdian
on Jul 10, 2017 at 5:00:34 pm
Hi, Ryan.
I too was led to believe that Premiere Pro was scriptable when I saw it listed in the Target Application drop-down menu in ExtendScript Toolkit.
If you happen to come across or get access to resources on that, it'd be awesome if you could share.
Cheers.
Peter Garaway
on Jul 10, 2017 at 9:31:48 pm
Hello Arthur,
Feel free to shoot me an email. I'd be happy to connect you with the right people.
Peter Garaway
Adobe
Premiere Pro
Bruce Bullis
on Aug 8, 2017 at 6:28:23 pm
The PProPanel sample is the place to start; it thoroughly exercises the PPro ExtendScript API:
https://github.com/Adobe-CEP/Samples/tree/master/PProPanel
Here's "How to set up a panel dev system":
https://github.com/Adobe-CEP/Samples/blob/master/PProPanel/ReadMe.md
Here's "How to debug panels at both the JavaScript and ExtendScript levels":
https://www.dropbox.com/s/lwo8jg0klxkq91s/walkthru.mp4
Feel free to ask questions, at my day job address: b b b at adobe dot com
jake pins
on Dec 3, 2017 at 10:59:50 pm
I'm also looking for a beginners guide for scripting in PP (2018).
I unfortunately dont have any scripting experience apart from some pretty simple python coding.
I am specifically looking to have script that will replace multiple pieces of footage from a number of sequences with files from a server using a spreadsheet that provides correlating material.
Alternatively, a script that would allow me to do batch replacement footage would also be a huge help
Jake.P
Taran Van Hemert
on Dec 28, 2017 at 10:41:08 pm
I believe this channel might have the information you're all looking for?
I've got this on my to-do list, but have not yet looked very deeply into it.
Harry Davidson
on Feb 26, 2018 at 1:57:11 pm
Hi Taran,
I was watching your last mega-tutorial and that got me on a hunt for some extra info on scripting in Premiere... funny to find you on this thread with a great suggestion.
Appreciate your work!
H
