DVD Files (.m2v and .ac3) not encoding correctly
Ariella Furman
on Apr 13, 2016 at 4:23:51 pm
Hello! I am using Adobe Media Encoder to create DVD files (fitting 120 mins on a disk) and it creates the 2 files and it says "Successful". However, the files it creates are a DIFFERENT time length than the actual raw Quicktime file. Or even when I export the DVD files from my timeline, it still ends up being a different time. In the case of my one export, the DVD file was only 39 minutes long when the timeline was 47 minutes long. I am marking my Out point correctly. In the case of my other export, it was only 50 minutes in length and the DVD file was 1 hour and 1 minute in length. Is there something I am doing wrong? Thanks!
Jeff Pulera
Re: DVD Files (.m2v and .ac3) not encoding correctly
on Apr 13, 2016 at 5:50:55 pm
I've never tried using Media Encoder to directly make MPEG-2 DVD files. Rather, I am exporting from the Premiere timeline and have never had any issues. Import your .mov file into Premiere, drop clip on timeline, and export to MPEG-2 DVD.
What is the frame rate of raw file?
Jeff Pulera
Safe Harbor Computers
Ariella Furman
on Apr 13, 2016 at 11:02:59 pm
Thank you for your response! Hmm, my preference is to throw everything into Queue so that I can encode both the high rez file and the DVD file at the same time while I am away from my desk, so that when I come back in the next day I can just start on a new edit. The video settings are 29.97 and the DVD settings are also 29.97. Has anyone else had this issue before? Thank you!
