fixing bad frames/dropped frames with a morphing technique?
JonZ MarZ
on Apr 13, 2016 at 4:29:22 am
I look for a simple solution to fix bad frames in clips that has dropped frames or tearing. I cut the bad frames manually, but I'm out of ideas how to make my workflow better. All I want is to create a morphed frame lets say B, between frames A and C (assuming that A is the frame before the dropped frame and C is the frame that resume the rest of the clip).
Any ideas?
thanks in advance
