audio popping on video capture
Chris Craig
on Apr 12, 2016 at 9:36:43 am
Hi all
I have 2 Mac computers. Each with the latest versions of premier pro. Im capturing video8 from a camera using firewire.
This morning when i began my video8 capture, the audio has a constant popping noise. I have tried a number of things from restarting, trashing the prefs, trying different hard drives to capture too and nothing has worked. I have also tried my second machine and the same thing is occuring.
Monitoring the audio from the camera and the sound is fine. Its in the transfer or so i thought.
I then used a different capture program called Vidi and this has managed to successfully capture the video and audio with no problems.
Can anyone shine a light on what could have messed up premiere pro as it has been isolated to that.
Thanks a lot
Jeff Pulera
Re: audio popping on video capture
on Apr 12, 2016 at 1:39:02 pm
Most MiniDV and D8 camcorders will record 16-bit 48k audio by default, but a few may offer 12-bit 32k audio recording. Make sure the capture spec matches what is on the tape or it can cause strange issues.
Jeff Pulera
Safe Harbor Computers
