Hide subtitle in premier pro
Tamas Toth
on Mar 27, 2016 at 10:54:52 am
I have a video that has subtitle on it. Is there any way to remove, paint over or hide that subtitle in premier pro?
Pierpaolo Ferlaino
Re: Hide subtitle in premier pro
on Mar 27, 2016 at 8:16:31 pm
If you're talking about burned in subtitles you can only blur, cover them with a black matte or something like that...
Jon Doughtie
on Mar 28, 2016 at 2:42:11 pm
Back in the ancient SD days, we would place a wipe on the footage that killed the first 25 lines or so, and record that to another source, then use the wiped footage in the production. This eliminated the lines with the closed caption encoding. I would think this would work for HD as well.
But that is if you are talking about closed captions. If you really are talking about subtitles, they are baked into the video, and you can only mask them or blur them.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
