VBR to CBR Frame Rate
Netta Yusef
on Mar 24, 2016 at 12:51:06 am
How to change VBR to CBR frame rate?
This is the frame rate I'm starting off with: 23.986030
I need to get 23.976
I've used Handbrake, Premiere, After Effects and FCP...Thoughts?
Chris Wright
Re: VBR to CBR Frame Rate
on Mar 24, 2016 at 1:13:22 am
try streamclip with quicktime png
Gary Milligan
on Mar 24, 2016 at 4:12:58 pm
[Netta Yusef] "How to change VBR to CBR frame rate?"
I don't have an answer for you, but I just want to clarify -
VBR = Variable Bit Rate
CBR = Constant Bit Rate
You are asking about FPS... Frames Per Second.
Netta Yusef
on Mar 24, 2016 at 4:54:02 pm
Thanks Gary, I guess I need to clarify that I need to get a constant frame rate.
Chris, I'm trying that right now. Should take a while, but I'll let you know if it works out. Thanks for your advice.
