2 issues found with CC 2015.02
Chris Borjis
on Mar 22, 2016 at 10:46:18 pm
Working on a documentary, found these two bugs: (mac version)
Exporting mono surround stems separately (for DCP/Blu-Ray)
Mute all but the one i need, export, then do the others.
the L track exported fine.
All other surround stems are empty with no sound/data.
Workaround:
Export files with none of the surround tracks muted and
check the box: "export as seperate files"
This way works. But so should the other.
Second, when exporting a prores file, if "maximum quality" is checked
even though I'm not downsizing I usually have this on in case of 720p or SD deliverables.
When it is on it is affecting cross fades and titles for some reason. Subtle but
there nonetheless and this appears to be a problem in CC 2015.01 as well.
