different formats and frame rates
Ludmil Kazakov
on Mar 21, 2016 at 4:05:14 pm
guys, just wanted to double check something. got a project with all sort of different formats and frame rates.. i plan on converting most of it to pro res so there are no issues.. but we do have some c300 footage which is at 29fps and need it to be at 24p.. lets say I make proxy files with 24p, would i have issues with drop frames when re-connecting in davicni? what would the best workflow be for that?
Shane Ross
Re: different formats and frame rates
on Mar 21, 2016 at 5:01:58 pm
Don't change the frame rate of the footage when you convert it. Keep the native frame rates. Adobe and resolve will deal with that part. If you change the frame rate, there's zero ability to relink to camera masters
Shane
Little Frog Post
