What proxy files would you recommend for a bare minimum windows machine as per Adobe system requirements?
Yair Bartal
on Mar 17, 2016 at 9:06:50 pm
That is for a final 10 minutes docu. video (A-roll + B-roll + background music) based on AVCHD H.264 1080p.
Either PP CC 2014 or CC 2015.
Thanks.
Duke Sweden
Re: What proxy files would you recommend for a bare minimum windows machine as per Adobe system requirements?
on Mar 18, 2016 at 1:47:17 am
I'm gonna tell you right now, when the big boys come to your post they're gonna ask you to provide your machine's specs so you may as well post them now. It'll make it a lot easier for them. Just saying bare bones means nothing. You could be running Windows 98 for all they know.
Yair Bartal
on Mar 18, 2016 at 5:06:18 am
Thanks duke for your response.
It could not be Windows 98 for example as that does not fit Adobe system requirements.
Anyway, it's an Intel Core2 Duo, Windows 7 64 bit, 4 GB RAM, one HDD 7,200 rpm, no GPU.
Duke Sweden
on Mar 18, 2016 at 10:49:23 am
I was being facetious. Now that you've added that information I'm sure the pros here will be better able to help you.
Tero Ahlfors
on Mar 18, 2016 at 12:48:11 pm
[Yair Bartal] "Intel Core2 Duo, Windows 7 64 bit, 4 GB RAM, one HDD 7,200 rpm, no GPU."
I'm not sure if a proxy workflow would even help. Your computer isn't that hot. You could try DNxHD LB and see if that runs.
Ann Bens
on Mar 18, 2016 at 2:16:44 pm
Technically its off line editing. Premiere does not do proxy.
I would go for dv avi in a 1920x1080 sequence. Dont scale up the footage but set progam window to 50-75%. then replace footage by original
Exporting is going to be a pain if it will export at all.....
Adobe Certified Expert Premiere Pro CS6/CC
Adobe Community Professional
Yair Bartal
on Mar 18, 2016 at 6:36:01 pm
Thanks Ann.
I'm not sure I understand the difference between offline editing and proxy footage usage, as it seems to be the same according to this link for example:
http://www.premiumbeat.com/blog/offline-editing/
Ann Bens
on Mar 19, 2016 at 11:40:57 am
If Premiere had a real proxy feature you would be able to switch between original and proxy files on the timeline very easily by just pressing a button.
Yair Bartal
on Mar 19, 2016 at 1:38:59 pm
OK, thanks Ann and thanks Tero for your advice.
Yair Bartal
on Apr 13, 2016 at 2:54:11 pm
Well, it seems this is coming in Premiere pro CC 2016.
