DVX100B 24pA footage in Premiere Pro CC2015
Andrew Rice
on Mar 17, 2016 at 4:19:43 am
I just got a project, long form doc, that was shot on the Panasonic DVX100b with 24pAdvanced. The footage was captured in FCP with the Advanced Pulldown option. see the screen shot.
I moved the project into Premiere, as FCP was EOL a long time ago. Nothing has been edited yet, so I am trying to figure out the best way to set up my sequence. I dropped a clip to auto-creat a sequence, but I see a lot of interlacing. Any suggestions would be great!
Andrew Rice
Kenai Productions
http://www.kenaiproductions.com
Andrew Rice
Re: DVX100B 24pA footage in Premiere Pro CC2015
on Mar 17, 2016 at 6:42:11 am
Just wanted to post a screenshot of the settings I am using on one sequence. This gives me "crappy" playback in the Monitor, and also some shots are very interlaced on my client monitor. The monitor is being fed by a BMD decklink studio card. Maybe I am just used to working in HD-UHD, but it should look better than what I am seeing.
Andrew Rice
Kenai Productions
Chris Wright
on Mar 17, 2016 at 11:37:31 pm
Right-click (Windows) or Control-click (Mac OS) a 24p clip in the Project panel.
Select Modify > Interpret Footage.
Under Frame Rate, select Remove 24p DV Pulldown.
Click OK.
https://helpx.adobe.com/premiere-pro/using/creating-changing-sequences.html...
Andrew Rice
on Mar 18, 2016 at 4:46:48 am
Thanks...but that option is greyed out. I cant select it. Even If i choose "assume this frame-rate" and put in 23.976, that option is greyed out.
Andrew Rice
Kenai Productions
Andrew Rice
on Mar 18, 2016 at 5:04:44 am
Also...when i open a clip in QT this is the limited info i have(see screenshot). Could there be a problem when the client is digitizing in FCP? I hope not, they have digitized a LOT of footage.
Andrew Rice
Kenai Productions
Chris Wright
on Mar 18, 2016 at 11:13:52 pm
aw, i see,
just use cinema tools-reverse telecine 2:2:2:4 advanced pa reverse pulldown
Andrew Rice
on Mar 18, 2016 at 11:23:07 pm
Thanks! Ill give it a try on some test clips, But I am beginning to think it was captured at 23.968 instead of at 29.97 as is recomended here:
https://larryjordan.com/articles/capturing-from-a-panasonic-dvx-100-camera-...
If it was captured in the "wrong" way I am guessing cinema tools wont be able to save us here, as the capture removed the wrong frames?
Andrew Rice
Kenai Productions
