AE comp speckle problem after Render Effects
John Goldsmith
on Mar 16, 2016 at 5:05:02 pm
I'm fairly new to Premiere Pro and have a problem with a comp from AE that seems to get a speckled effect once I hit "Sequence / Render Effects in to out".
Prior to hitting enter it looks like this:
and once I have hit enter it looks like this:
My workflow is to take a clip in PP and select 'Replace with After Effects Composition'. I then import an Illustrator file, convert the vector layers to shape layers, add some keyframes and then save the project. Back in PP I get the speckle problem. In AE eveything looks fine (a nice solid colour) and in PP too, until I hit the enter key.
Any ideas on what I'm doing wrong?
Best regards
John
Current setup:
Premiere Pro CC 9.2.0 (41)
After Effects CC 13.7.0.124
John Goldsmith
Re: AE comp speckle problem after Render Effects
on Mar 17, 2016 at 1:56:45 pm
So I'll reply to my own post as I've discovered that it appears not to be a AE problem, but also occurs in other parts of the sequence. I've also found that unchecking "Composite in Linear Color" in Sequence Settings, solves the problem.
I'm not completely clear on why Linear Color creates the speckled effect, but at least I now know how to fix it.
