3 or 4 point editing prompt menu / window got turned off accidentally
Yvette Choy
on Mar 8, 2016 at 11:03:23 pm
Hello,
When doing a three point edit in Premiere Pro 2015, a menu/window prompt appears allowing one to choose Fit to Fill, Ignore source in or out point and Ignore sequence in or out points. Being a curious new explorer to this program, I checked the box on the bottom that said "Always use this option."
I thought it would have the option I chose already selected every time the menu/window prompt appears. However, instead, the menu/window prompt no longer appears. Does anyone know how to get it to re-appear again? How do I uncheck that option if that option is no longer given?
Thanks so much!
Yvette.
Massimo Alberto Croce
Re: 3 or 4 point editing prompt menu / window got turned off accidentally
on Mar 9, 2016 at 6:14:24 pm
go to general preference and check "fit clip dialog opens for edit range mismatches"
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Yvette Choy
on Mar 10, 2016 at 5:06:20 pm
Voila! Thanks so much for this helpful answer! :-)
on Mar 10, 2016 at 5:09:42 pm
you are welcome!
