Can u export in multiple frame rates?
Matt Peterson
on Mar 5, 2016 at 1:12:07 am
I have a film I made that's about 60 minutes. It was shot at 24fps, except for 30 seconds of footage at 30fps. When I go to export at 24fps the 30fps footage comes out choppy. Is there any way to fix this, can u export in multiple frame rates?
Chris Wright
Re: Can u export in multiple frame rates?
on Mar 5, 2016 at 1:58:04 am
in this case, I would recommend optical flow if you wanted to keep a 24 timeline.
http://blogs.adobe.com/premierepro/2015/12/optical-flow-time-remapping-tips...
Matt Peterson
on Mar 5, 2016 at 2:54:55 am
can I get optical flow for CS6?
Chris Wright
on Mar 5, 2016 at 3:21:27 am
if you have After Effects CS6, it has optical flow/timewarp
Mac has compressor, FCPX has it built in
Twixtor is available from REvision as a plugin
then of course there's hardware devices like the Terenex 2D and Aja FS1-X
or if you like scripting, there's ConvertFPS for avisynth.
