Aspect ratio: 'square pixels' or '4x3 standard'?
Oscar Gotti
on Mar 2, 2016 at 9:44:20 pm
So my sequence is 1920x1080, and all my footage is also 1920x1080 square pixels.
I have to deliver an SD version: 720x480/4:3 aspect ratio.
My question is:
In the export settings, what setting do I choose for the 'aspect ratio' setting: 'square pixels' or '4:3 standard'?
Mayto
Jon Doughtie
Re: Aspect ratio: 'square pixels' or '4x3 standard'?
on Mar 2, 2016 at 9:54:26 pm
If your SD center cut is for the old American NTSC standard, you would want "standard 4:3". That is a .91 pixel aspect ratio.
Also, if that is American NTSC, it would be lower field first.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Jeff Pulera
on Mar 2, 2016 at 9:58:28 pm
You are going from a 16:9 widescreen source to a 4:3 output. What Format are you exporting to? Meaning H.264, DVD, something else?
640x480 output would use Square Pixels.
720x480 is "DV" and uses 0.9 pixel aspect
So, if output is requested at 720x480, then you don't want square pixels (1.0), rather you want the 0.9 setting. Instead of creating a "custom" output setting, you may find an "NTSC DV" preset after choosing a Format, and that will have the correct settings. For instance, "NTSC DV" is found under H.264, AVI, and MPEG-2 DVD formats.
Another consideration - converting from 16:9 source to 4:3 output
In Export Settings window, look at upper left under Output tab. You will see Source Scaling, and it provides 3 options:
Scale to Fit = will letterbox 16:9 in 4:3 frame, black bars top and bottom on export
Scale to Fill = center crop, sides of image cropped off leaving 4:3 center
Stretch to Fill = image horizontally compressed to fit 4:3 frame, people get taller and thinner
You can choose the different options and see results in preview window
Jeff Pulera
Safe Harbor Computers
