Export settings for hd (weird lose in quality)
Daniel Turner
on Feb 27, 2016 at 12:39:18 pm
I've animated in flash AND have exported as a quicktime mov. When I export in premiere the image is faded and pixelated.
Im going for 1080
Originalflash .mov export:
premiere export
Tero Ahlfors
Re: Export settings for hd (weird lose in quality)
on Feb 27, 2016 at 6:01:23 pm
I'm not seeing any obvious pixelation in that screenshot. I don't know what the original format is but everytime you compress you're dealing with the format you're compressing in. It will not be 1:1 pixel copy especially if you are expecting vector quality. Those bitrate targets are overkill unless you're dealing with 4K resolutions and up.
Is there a reason your timeline is HD anamorphic (1440x1080)?
Daniel Turner
on Feb 28, 2016 at 9:47:04 am
Right I figured it out.
It wasn't the export settings but the intial sequence settings that needed to be custom setup.DVHDPRO
Tero Ahlfors
on Feb 28, 2016 at 10:21:42 am
Why exactly are you using HD anamorphic pixel aspect ratio? That's pretty much a camera acquisition resolution and not something that would be used in broadcast or internet.
