How to display multicam sequence after trimming in expand tracks mode?
leaning less
on Feb 22, 2016 at 11:53:48 am
After editing i need to get edited sequence in expand mode (as on a chess board), but not source sequence. Such action is in Vegas Pro (Expand to Multiple Tracks).
Herb Sevush
Re: How to display multicam sequence after trimming in expand tracks mode?
on Feb 22, 2016 at 1:06:57 pm
[leaning less] "After editing i need to get edited sequence in expand mode (as on a chess board), but not source sequence. Such action is in Vegas Pro (Expand to Multiple Tracks)."
Your question might make sense in "Vegas" speak but it's gibberish in a Ppro forum. What is expand mode and why do you want to use it ?
Herb Sevush
Zebra Productions
nothin' attached to nothin'
"Deciding the spine is the process of editing" F. Bieberkopf
Alex Udell
on Feb 22, 2016 at 3:09:03 pm
He wants to checkerboard the edits between a couple of tracks, I think...
since you have multicam edits...
with the sequence panel active
use the Find Command (command or control F)
search for all clips with a matching name
Find ALL
drag to a different video layer...
that ought get you where you want to go....
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
leaning less
on Feb 23, 2016 at 6:41:19 pm
Thank you! Probably this method solves my question. But how to drag the video to different layers if each of the seven cameras has more than hundred of files? Or i need to find selected video in project on timeline (Reveal in Timeline) for selecting and drag all videos from first camera, second and so on.
Alex Udell
on Feb 23, 2016 at 9:48:56 pm
if you have 7 cameras
then you have to "FIND ALL" in the sequence for each one 7 differnt clip names...one per camera).
when you FIND ALL...it will select all items with that name in the sequence.
when they are highlighted....
you can drag them as a group to a different track...
Alex Udell
leaning less
on Feb 25, 2016 at 9:26:50 am
Thank you! But my question resolved with Multicamera -> Flatten. And also Label -> Select Label Group.
Alex Udell
on Feb 26, 2016 at 3:12:17 pm
Ahh....this was not clear that you wanted to get to underlying source clips....
Alex Udell
