GoPro Hero 4 2704 x 1520 (2.7) format
Greg Flory
on Feb 18, 2016 at 7:31:35 pm
Used above format to create residential interior video. 2704 x 1520 resulted in much wider field of vision and detail than 1920 x 1080.
Is it possible to add 2704 x 1520 to Premiere Pro CS6 timeline and "zoom out" to 1920 x 1080 for export rather than crop? Is this available in CC version of Premiere Pro?
Greg Flory
Tero Ahlfors
Re: GoPro Hero 4 2704 x 1520 (2.7) format
on Feb 18, 2016 at 8:14:34 pm
You can put the footage in a full HD sequence then right click it and choose scale to frame size. The aspect ratio is pretty much the same so it isn't really wider.
Tim Kolb
on Feb 22, 2016 at 11:11:04 pm
If you use the motion controls (scale), you can be a bit more flexible...zoom in/out, etc with key frames in an HD sequence. You've got some real estate to play with there.
TimK,
Director, Consultant
Video Producer at I-CAR
