Rendered frames don't match result frames inside Color Finesse using Adobe Premiere
Gerald Peters
on Feb 11, 2016 at 3:27:00 pm
I am running the latest version of Adobe Premiere on Windows 7 64bit. The frame rendered by Adobe Premiere is significantly brighter than the one shown inside the full UI of Color Finesse. Everything matches with After Effects, but I want it to work with Premiere.
Here are two screen shots, one inside Color Finesse, the other inside Premiere. My sequence settings are visible on the left. You’ll notice the clipping on the girl’s shoulder is much different between the two.
I should add, that if I step forward one frame in Adobe Premiere the image matches the one in Color Finesse, but then after a short pause the frame image updates in Adobe Premiere to one with too much brightness.
