Cut IN and OUT points simultaneously?
Jimmy Wanamassa
on Feb 11, 2016 at 4:11:06 pm
I have a clip in the Sequence. I set my IN an OUT points in the middle of this clip. I want to cut at both the in and out points simultaneously (preferably with a shortcut), so I can then ramp speed on this new clip. Does this exist in Premiere Pro CC 2016?
*Is there a function to cut at both in and out?
Right now I'm cutting at IN point then moving over to OUT and cutting again. As always, just trying to save a few clicks ;)
Tero Ahlfors
Re: Cut IN and OUT points simultaneously?
on Feb 11, 2016 at 5:15:02 pm
I haven't stumbled upon such a feature. The keyboards shortcuts for go to in/out is shift+i/o so it doesn't need that many key presses. Or you could cut as you go with a keyboard shortcut instead of using the blade tool.
Jimmy Wanamassa
on Feb 11, 2016 at 5:18:48 pm
Cool, yea I'm using those. It's just interesting they have lift and extract but not "split" or something of the like. Thanks!
Alex Udell
on Feb 11, 2016 at 6:21:44 pm
If you go to the IN point and LIFT the marked area...
(leaving a gap)
then (assuming your tracks are patched properly)
Paste
does this get you what you want? (lift should put your lifted clip in the clipboard)
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Jimmy Wanamassa
on Feb 11, 2016 at 11:47:19 pm
Thanks Alex, but it's just as many clicks as cutting at in and out. I just didn't know if my desired action was called something I was unaware of.
Paul Neumann
on Feb 12, 2016 at 1:04:12 am
So roll up to the IN point and Cmmd K. Roll up to the out point and Q.
