Is there a way to automatically scale a clip to a certain size?
Bill Bill Cleffrough
on Feb 6, 2016 at 3:20:10 am
So I have a clip that I want to cut up and intersperse throughout my video, but I would like it to be at about 90% size when I drag it onto the timeline. Assuming I were to do what I normally do and just drag the clips from the source monitor where I need them, I would have to individually adjust the scale on each one. And I cannot copy and paste attributes onto each one, because I'll be doing a lot of panning and zooming that would be reset by this.
The only method I know of would be to downsize, then nest the clip into a new sequence, but this would mean that I'd need to render out the effects that I apply. Does anyone know of a way I can automatically set the scale of my clip? (And I am not scaling to frame size.)
Tero Ahlfors
Re: Is there a way to automatically scale a clip to a certain size?
on Feb 6, 2016 at 8:21:44 am
https://helpx.adobe.com/premiere-pro/using/master-clip-effects.html
Larry DeGala
on Feb 6, 2016 at 11:21:31 am
apply 90% scale to all clips first. then do your custom pan&scan afterwards. after all, you cannot properly pan&scan until you compose your frame to the 90% scaling, right?
http://www.imdb.com/name/nm4425233/
