Thin Vertical Bars I can't get rid of on the side of my video
Ian T. McFarland
on Feb 3, 2016 at 2:19:10 am
Hoping y'all can help me with a bit of a humdinger I've had on my hands. In some but not all sequences I work on in Premiere CC 2016, the canvas has appeared to widen by, I would guess, about five pixels. This is not the case, though - because when I pull up sequence settings, I can see that the project is in 1920 x 1080 (just like the footage I'm using,) and pixel aspect ratio is square.
My current problem sequence was duplicated from a sequence where this is not an issue, so my guess is that I'm accidentally - and frequently - creating the problem, but I can't even figure out what the problem is. Whatever the issue is, I don't believe it can be changed in sequence settings, as I've compared sequence settings from problem sequence and normal sequences and they are identical to each other.
There are a couple of short term solutions to this - scale all the material up to 101%, copy and paste everything into a new timeline - but I was hoping someone might know what I'm talking about, because this problem keeps popping up and I'd prefer to have a long-term solution.
Jeff Pulera
Re: Thin Vertical Bars I can't get rid of on the side of my video
on Feb 3, 2016 at 2:43:24 pm
Where are you viewing the issue - in the Program Monitor window? Or at Export? Screen shots of settings and issue are helpful.
Jeff Pulera
Safe Harbor Computers
Ian T. McFarland
on Feb 3, 2016 at 6:13:40 pm
Thanks for your response - the issue is appearing both in the Program window and in exports. Below are the images you requested.
Jeff Pulera
on Feb 3, 2016 at 6:25:08 pm
Any chance the black edges are on the Source clips themselves? Can you check them in QT player or something maybe? Otherwise, with 1920x1080 clips in a 1920x1080 sequence, I have no answer.
One more thought, were the clips shot as 1080 or maybe downsized from 2K or 4K?
Jeff Pulera
Ian T. McFarland
on Feb 3, 2016 at 6:30:52 pm
The black edges are not in the source clips (neither the RAW nor the transcodes), and they were shot in 1920 x 1080 as well.
Yeah, I'm stumped.
Jeff Pulera
on Feb 3, 2016 at 6:48:15 pm
Please try this - make a New > Color Matte, use a bright color
Drop that into sequence - does that have black edges?
Jeff Pulera
Tero Ahlfors
on Feb 3, 2016 at 6:50:28 pm
If you have GPU acceleration enabled try turning it off.
Ian T. McFarland
on Feb 3, 2016 at 7:03:39 pm
Turned of GPU Acceleration and that did nothing.
But Jeff - the color matte appeared in the sequence without the black bars, so you may be onto something.
