PP CS 2015: Take clips from larger video files but NOT import / conform entire video.
Jim Guteriez
on Feb 2, 2016 at 9:04:33 pm
Im on PC Adobe Premier Pro CC 2015 and have a question i have not been able to search out a solution to (nor find someone with a similar question, although i know it has to be a common issue).
I have several 3-5hour clips (10-20 GB each), from which i need to grab one or two 5 minute clips from, to then use in a PP project.
How can I pull or import just the 5 minute blocks of video from these larger clips, without having to import or conform the entire 5 hour clip?
Another way to state this question (with time-code examples):
ie I have a 14gb 5hourVideo.avi i need to extract just 3h 42m to 3h 38m, and use that clip in my PP project. Currently i would have to import (or drag into my media bin / media browser) the entire 5 hour, 14GB video , then cut out my clip. When i do this PP begins conforming the entire 14GB video (as it should), is their a way to import just the 3h 42m to 3h 38m so the entire file is not conformed? ( i need to do this same function from several 5 hour .avi video clips).
Alex Udell
Re: PP CS 2015: Take clips from larger video files but NOT import / conform entire video.
on Feb 3, 2016 at 2:09:34 pm
Hi....
The answer might be After Effects.
Less prone to having to deal with the conform issue.
Import it....find the sections you want...
export as new clips in a friendly codec.
Alex Udell
Editing, Motion Graphics, and Visual FX
Let's Connect on Linkedin
Examples: Retail Automotive Motion Graphics Spots
Example: Customer Facing Explainer Video
Example: Infotainment & Package editorial
Tero Ahlfors
on Feb 3, 2016 at 2:40:46 pm
Have you tried Prelude?
Peter Garaway
on Feb 11, 2016 at 6:43:20 pm
Agree with Tero.
Take a look at Prelude. Here's an older video tutorial but should cover what your after.
http://tv.adobe.com/watch/cs6-creative-cloud-feature-tour-for-video/how-to-...
Best,
Peter Garaway
Adobe
Premiere Pro
