Audio bit rate
Oscar Gotti
Audio bit rate
on Jan 31, 2016 at 10:07:12 am
I am being asked to do an export with only a bit rate of 128kbps for audio. In this case, is it better for the quality of my audio if I export the audio mono?
Surely if I export stereo each channel will only be 64kbps each... rather than having one mono channel with 128kbps?
Tero Ahlfors
Re: Audio bit rate
on Jan 31, 2016 at 12:30:25 pm
[Oscar Gotti] "Surely if I export stereo each channel will only be 64kbps each.."
No. The audio bitrate is used for the entire audio track. It's not split for the channels. There's no reason to export stereo as mono unless there's some weird/special specification for it eg. some reaaally old playback device.
https://en.wikipedia.org/wiki/Data_compression#Audio
Oscar Gotti
Re: Audio bit rate
on Jan 31, 2016 at 3:12:48 pm
Interesting, I was told on a forum on Facebook that 128kbps exported mono will sound much better quality than 128kbps exported stereo. Is there any truth to that?
Jon Doughtie
Re: Audio bit rate
on Feb 2, 2016 at 10:00:08 pm
I do not think most folks would hear any difference. It also depends on the source material.
128k is usually the lowest "acceptable" bit rate, so some folks may find their ears are more sensitive to the limitations of that particular setting.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2014 (as of 7/2015)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.
Chris Wright
Re: Audio bit rate
on Feb 3, 2016 at 6:33:37 am
if you use AAC, even 64kbps should sound good. it's the replacement for mp3.
if you use a special mono only file, the file size will be the same!, but you can squeeze in more quality for the same file size. and if you recorded with a mono microphone, there's no point in stereo anyway unless you are panning or split the music and vocals.
