Stereo Audio
Eric Merklein
Stereo Audio
on Jan 29, 2016 at 7:05:40 pm
I imported stereo music into my project.
Even though I have my audio settings set to stereo, the music shows up in my timeline as a single channel. The VU meter shows two separate sources in play, but again I only have one track of audio.
Is there a setting that will allow me to have 2 separate channels?
Thanks much.
Eric
Many thanks.
Shane Ross
Re: Stereo Audio
on Jan 29, 2016 at 9:04:52 pm
Your audio imported as a single, stereo file. and your timeline also has a track that is a single track, but a STEREO track. There are two types of tracks...Mono and Stereo. Stereo tracks are good because they allow you to use a single track for a stereo file, instead of wasting space on two tracks for this same file...since we rarely, if ever, make changes to one channel, but not the other.
You can change the clip if you want...just right-click on it, choose MODIFY then AUDIO CHANNELS. And then in the PRESET drop down menu, choose MONO and you'll get two mono channels that you can do with what you will
Shane
Little Frog Post
Eric Merklein
Re: Stereo Audio
on Jan 29, 2016 at 9:47:00 pm
Awesome! Thanks much Shane.
Eric
Many thanks.
