Can't install Premiere Pro, stuck on installing redistributable package 2012
Omur Sonmez
on Jan 24, 2016 at 11:54:42 pm
I have been having this problem installing Premiere Pro 2014 and 2015. Whenever it gets to installing the redistributable package of 2012, it gets stuck. I manually installed it myself, but still the install is stuck on that part. I restarted several times, uninstalled the redistributables, then reinstalled them. None of it seems to work.
I also tried installing as an admin, still the same result.
Tim Kolb
Re: Can't install Premiere Pro, stuck on installing redistributable package 2012
on Feb 7, 2016 at 1:22:16 am
Are you running McAfee with real-time scanning? If so, turn real-time scanning off and try the install again...
TimK,
Director, Consultant
Video Producer at I-CAR
