old video format
therman mermehn
old video format
on Jan 24, 2016 at 3:52:52 pm
what the oldest format I can output in premiere?
I have an old pentium 1 computer , yes pentium 1 , that I want to play videos. The machine seems to be able to play any file that is .mpg and is 1500kbps max. For example , the sample commercial videos on the windows 98 disk play fine and look good.
So what exact codec should I use to get an mpg format and the right audio format? the closest I could get was .wmv but the machine laggs a bit when playing those and the audio doesn't seem to work.
Vince Becquiot
Re: old video format
on Jan 25, 2016 at 3:34:53 am
The best format is going to be the one that doesn't require a lot of CPU processing. If you don't need HD, you could try DV.
Vince Becquiot
Indigo Live | Kaptis Media
San Francisco Bay Area
Chris Borjis
on Jan 25, 2016 at 7:31:42 pm
mpeg2 program stream at 5mbps vbr should work
that should include mpeg1 audio layer II audio.
